Ive had a problem for about 8 months and cannot seem to get help to fix it.
Ive tried logitech gaming software, Ghub
And i also went and purchased a steel series mouse thinking the g502 mouse was busted...
Nope still having an issue.
Macro will not left click for me its a simple macro that i used to use it wont work anymore... I recently upgraded my pc and decided maybe a fresh install of windows will do the trick nope still having the same exact issue.... Ive tried everything someone pleassseee help!!!!
Macro is so simple
(Press key 0 delay for 25ms left click)
Asus Rog strix Z390-e gaming
PNY Anarchy 2133MHz 2×8gb ram / OC to 3066MHz
I7 8700
MSI Gtx 1660 gaming X
Stock CPU cooler
https://linustechtips.com/topic/1158930-help-with-macro/
