First time posting a question here and building pc.
What is the best budget Graphics card should i buy? I heard that the RX580 8Gb is the best for budget builds but im thinking about the future as it is an old card.
Sorry in advance for the mistake. Cheers
https://linustechtips.com/topic/1158334-first-time-building-a-pc/
First, what's the primary use of this system?
Second, it looks like you're coming from Aussieland, correct?
My understanding, from suggestions I've seen for B450 mATX boards here is that the B450m Mortar is the best value in it's price bracket.
The Q300L is plagued with the same airflow issues highlighted in the Q500l review GN has done. It's worth considering this, particularly for a region of the world well known for getting quite toasty during hot months.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
Quote
Yes, I do live in the land down under and it gets scorching hot here.
It will be used primarily gaming but wanted it bulletproof for the next couple of years.
I am talking all advice as I am a novice when it comes to this.
One of my main concern is the GPU as there is a lot of cards that they call "budget oriented" and i don't know that to do with that information like the 1660, 1660 ti and 1660 super. There is so many chooses and I don't want to mess up.
