25 minutes ago, idwt said:
what cables are we talking about?
also i know this wasnt a part of the question, but i would reccomend giving your PC a quick de-dust, looks like its building up a little bit
Firstly, i can't escape the dust however much I clean it so I clean it every few months.
Secondly, the cables I'm worried about are the USB 3.0 and the USB 2.0 and the SATA PORTS .
https://linustechtips.com/topic/1158014-will-it-fit/#findComment-13315713
usb 3.0 and 2.0 are fine because they are above the PCIE slot.
and im not sure on SATA, but i cannot see why they would build a board that cant fit a "full size" graphics card,
https://linustechtips.com/topic/1158014-will-it-fit/#findComment-13315716
You're fine m8.
The length of the case is usually the limit. I don't know which case it is and don't see the full length in the pics but that should also be fine.
It's an old card though and you might wanna get something like an Rx 5500 XT or so instead.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1158014-will-it-fit/#findComment-13315718
having a little look i think the SATA ports will be fine, my GPU sits over an inch away from my motherboard.
and looking at it the SATA ports sit out around the same height/width as the PCIE slot, and you often get a few extra mm where the GPU plugs in,
im 99% sure you will be fine
https://linustechtips.com/topic/1158014-will-it-fit/#findComment-13315721
Just now, idwt said:
do you have negitive pressure in your case? might be causing all the dust
It's that the case doesn't have the best dust filtration and that the spot I have my PC at has a lot of dust build up. But I don't really have any other place to put it that it could help.
https://linustechtips.com/topic/1158014-will-it-fit/#findComment-13315729
ahhh okay, its just that negitive pressure in a case is a pretty common mistake
https://linustechtips.com/topic/1158014-will-it-fit/#findComment-13315731
