What parts? What case? How many fans? What cooler?
Which BSOD are you getting?
2 minutes ago, tati4kata said:
I've got some old cpu that's FX8350 (stock)
Gt 640 (heavy overclock)
140mm intake and outtake and wait a minute for the case
How old are all the components? Did you buy them new?
Rainbow Barf
CPU: i7-12700K GPU: RX 6800 XT RAM: 64GB DDR4 Storage: 2TB NVME SSD RAID - 1TBx2 NVME SSD - 8TB HDD
Lenovo Legion Pro 5i
CPU: i7-12700H GPU: RTX 3070 Ti RAM: 32GB DDR5 Storage: 1TB + 1TB SSDs
The parts are:
GT630 (heavy overclock)
FX8350 (stock)
Case is cooler master TD500
140mm BeQuiet fans
and a asus m-something i think
Just now, tati4kata said:
Acually from a friend that barely used them
and said he didn't need them so he gave them to me.
Do you know which component is overheating? Have you used a program like HWmonitor to check?
Rainbow Barf
Its the cpu but the gpu is also running on 85 - 90 C°
From someone who has owned a 8350 they run hot, what CPU cooler are you using and when was the last time thermal compound was applied. And are you sure a overclock wasn't set in the BIOS for the CPU when your friend had it?
Also since the GPU is older it may need new thermal compound but you will also need to make sure there is good airflow in your case with a heavy overclock on it, especially with both of those components pumping out hear if there is not enough airflow in and out of the case it will just cause everything to overheat, take it from me, I had 2 R9 290x and a 8350 at one point and time.
Rainbow Barf
you should go into the motherboard BIOS and increase the fan speeds. If the parts are overheating it means you probably are not getting proper airflow.
Primary PC:
PSU tier list
How many watts do I need?
Tried but didn't work.
if the fans are spinning real fast and it's still overheating, something else is wrong. Are you smothering the fan intakes?
Primary PC:
PSU tier list
That is the thing. The fans aren't spinning but they spinned on one of my other PCs. I don't get it
With the fans not spinning, sounds like a potential defect with the motherboard
Primary PC:
PSU tier list
