You're totally fine using the stock paste. Sure, you can get better temperatures with better pastes, but if you're looking for "good enough", the stock stuff fits that requirement.
https://linustechtips.com/topic/1155961-thermal-paste-quality/#findComment-13299181
Just use stock paste. Especially with a budget build. You'll maybe see 1-2C difference.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1155961-thermal-paste-quality/#findComment-13299194
It's good to use a paste that doesn't have thermal cycle "pump-out".  Had a paste do that over 6 months and when I removed the cooler there was barely any left on the IHS.  I now just usually stick with kryonaut, no curing issues, nothing and it lasts almost as long as my IC graphite thermal pads.  I also don't recommend the pads, more times than not, just lower a cooler onto them can move them out of place.
https://linustechtips.com/topic/1155961-thermal-paste-quality/#findComment-13299287
