Hey there! I'm building a new PC and I'm basically done picking the components, I just need to pick a case. Possibly 150£, 200 at most
Components that matter in terms of space follow:
Asus Rog B450-F
Ryzen 7 3700X (Probably gonna use the default cooler as I don't plan on overclocking it, maybe I'll get an aftermarket cooler later on, so room for a tall cooler is always good)
Gigabyte Aorus RTX 2080 Super Waterforce (AIO), which I would like to mount vertically
An HDD and NVMe
Thermaltake Toughpower Grand 750W
Now, I was initially going to go with an NZXT H700 but I need a case that supports vertical GPU mounting as I'm don't really like the way the cables go through if you use a vertical mounting kit on a case that doesn't support it by default.
So what I'm looking for:
- Large case
- Tempered Glass panel/s
- Vertical GPU mount
- PSU Shroud
Thanks in advance!
https://linustechtips.com/topic/1155797-case-recommendation/
