budget?
the stock cooler is certainly good enough, unless you have lofty OC goals.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1155261-which-air-cooler/#findComment-13294271
7 minutes ago, EchoBlue said:
No overclocking.
What is the ideal temperature?
Not sure about the budget yet.
I want to get some facts first.
Thank you
Temp sub 85 us good, sub 80 is usually ideal.
The only way to know about cooler performance is to look up reviews and stuff with data, you can't really judge by looking
Primary PC:
PSU tier list
https://linustechtips.com/topic/1155261-which-air-cooler/#findComment-13294293
Wow. I guess some of the coolers I have been looking at claim their temp is idle at around 55.
In C not F  right?
Do you know what the temp for the default cooler?
https://linustechtips.com/topic/1155261-which-air-cooler/#findComment-13294300
In C not F  right?
Can you link some of those? Generally, looking at reviews is better than looking at marketing material. Temps in PCs are always in Celsius.
The stock cooler performance depends on actual CPU. the R7 and R9 CPUs (3rd gen) are bit too much for stock cooler to handle. Pretty much like i7 and i9 are for Intels side. But in general, stock idle is 45C and load is 75-80C. Using good aftermarket cooler can drop 10C off from those.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1155261-which-air-cooler/#findComment-13296578
It was the Cooler Master newest air cooler.
Load was 55C I believe.
I'm hearing that if you are not going to be OC then you don't need aftermarket cooler.
What do you think?
I'm planning to get AMD Ryzen 5 or 7.
https://linustechtips.com/topic/1155261-which-air-cooler/#findComment-13297617
7 hours ago, JohnnyImport said:
Noctua NH-D15
Somewhat irrelevant picture. Max temps looks like you just started Chrome or something.
What do you think?
3rd gen R7 is having issues with stock cooling, and even some budget aftermarket coolers. You can look at other threads here to see what the recommendations are.
When you start looking at cooler, budget, case and RAM are main things you need to know. Case and RAM will determitnate what size coolers you can actually use.
https://linustechtips.com/topic/1155261-which-air-cooler/#findComment-13297625
