Could be coil whine, which while annoying, isn't really a technical problem.
What model PSU do you have? Is it old?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1154783-psu-noise/#findComment-13290386
Just now, Jkri4192 said:
Corsair 500w 80+ bronze
so it's probably pretty old. wouldn't be a bad move to replace it honestly.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1154783-psu-noise/#findComment-13290988
1 minute ago, Jkri4192 said:
What do you recommend swapping to?
depends on what your budget would be, and your specs.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1154783-psu-noise/#findComment-13291074
4 minutes ago, Jkri4192 said:
Around 100 bucks and I want to upgrade it anyways because I want to upgrade my gpu to a 2060 super or 2070 super and I have a amd ryzen 5 3600 in it
https://pcpartpicker.com/product/bqVD4D/corsair-rmx-2018-550w-80-gold-certified-fully-modular-atx-power-supply-cp-9020177-na
Primary PC:
PSU tier list
https://linustechtips.com/topic/1154783-psu-noise/#findComment-13291104
