Hi Guys, I am a new user here and hope that you can help me.
I have a Macbook pro 13 2019 and use a usb c Hub from anker (7 in 1 ). My issue is that the cable is too short and I want to extend the cabel. I bought a usb C male to female cable (which says supports thunderbold 3 ) but then my Peripherals wont work so I gave it back to the reseller. is there any cable that could fit my problem
(sorry for my english and grettings from germany )
https://linustechtips.com/topic/1154116-usb-c-hub/
To do this you would need a male to female *thunderbolt* cable, like this one:
https://www.amazon.com/DISDIM-Thunderbolt-Extension-Charging-Compatible/dp/B075MBS6JY/
i like trains 🙂
https://linustechtips.com/topic/1154116-usb-c-hub/#findComment-13285323
