KSP Firespitter Mod Help
Go to solution Solved by Snapy1,
the right fuel?
Yep, I tried a different propeller, and now its working fine. I first tried the 4 fin one, now I tried the 3 fin one and it worked fine.....Hmm KSP is weird sometimes.
Okay I made my aircraft with the mod, its a bi-plane, and whenever I throttle all the way down the engine will start, be whenever I throttle up the tiniest bit they die, any help, like am i doing the controls right?
https://linustechtips.com/topic/115403-ksp-firespitter-mod-help/
Shift to accelerate and ctrl to throttle down, correct?
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
https://linustechtips.com/topic/115403-ksp-firespitter-mod-help/#findComment-1542807
Doesnt work, whenever I accelerate the engine die's and whenever I throttle to zero the engine start but dont take me anywhere.
https://linustechtips.com/topic/115403-ksp-firespitter-mod-help/#findComment-1542816
enough electricity? they're power hungry.
and some still need intake air.
Its not an electric one, its an fuel engine, and intake air shouln't* be a problem, I got a shit load of fuel so fuel aint a problem
https://linustechtips.com/topic/115403-ksp-firespitter-mod-help/#findComment-1542842
the right fuel?
https://linustechtips.com/topic/115403-ksp-firespitter-mod-help/#findComment-1542874
