Hello, I want to add one more 8 Gb ram module for dual channel but I don't know what to choose. My laptop model is Lenovo Legion Y520-15IKBN 80WK00Y9RI. I have this installed from factory: 8Gb Ramaxel RAMRMSA3260MH78HAF-2666 and I need one more for proper dual channel but I can't find any Ramaxel in my country. Also, I looked up for specifications on my laptop's manufacturer website and it says it only supports 2400Mhz so why does it really have 2666MHz installed ?
Here are some informations from CPUZ:
MemoryCPUZ
SPDCPUZ
Thank you!
https://linustechtips.com/topic/1152864-need-help-chosing-ram/
Installed stick supports up to 2666, but it is running at 2400 (CPU-Z, Memory Tab, Timings section, DRAM Frequency).
Finding same memory is hard, especially since Ramaxel isn't very known manufacturer. What you can try is finding memory with same (or as similar as possible) capacity, frequency and timings. Some laptops are very picky about memory, so you'll have to hope for the best.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1152864-need-help-chosing-ram/#findComment-13275908
