I'm going to be installing some RAM for a friend (he doesn't trust himself not to mess it up) and I have a question.
While I do know how to install RAM on the motherboard, I'm not sure about after that.
What I mean is: will the RAM work straight away after installation or does something in the BIOS have to be changed or similar software related stuff have to be done afterwards in order to make it work?
I got sent to prison after following Linus' instructions to #Makebombs
Forum's resident nihilist.
A JRPG just wouldn't be a JRPG if it didn't end with teenagers using the power of friendship to kill God.
https://linustechtips.com/topic/115196-small-question-about-ram-installation/
uh, you might have to go into the bios and check if it's recognized, and the speed it's clocked it is correct.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
but other thant this ^^ it's plug and play
Case: NZXT Phantom 410 Cpu: i7 3820 at 4.3 Ghz Motherboard: Gigabyte GA-X79-UP4 | Gpu: XFX hd 7970 Ghz 1100Mhz/1600Mhz Ram: Crucial BallistiX Elite 16GB 2x8 Gb 1866 Mhz
SSD's: 2x Kingston HyperX 3K SSD 120 GB in RAID 0 HDD:Seagate Barracuda 2TB 7200 Rpm
Cpu cooler: Corsair H100i with SP120's | Psu: Corsair TX 850W My monitors: 3x BenQ 24"  GL2460 = Eyefinity
