Hi, I need help choosing components for a machine whose purpose is to receive and reproduce content, via Resolume Arena or vMix, up to 4k 60fps, on LedWall panels of different sizes (they can be quite large, like 8 meters by 6 meters) and, if possible, have at least 5 outputs running simultaneously.
Case + components only.
The budget is a bit indifferent but the less you spend the better.
Thanks in advance.
https://linustechtips.com/topic/1150905-need-help-for-a-build/
Hey there,
I put together a list around the Radeon Pro W5700, as it is a little bit stronger than the RX 5700 and comes with five Mini Displayports 1.4 which can drive 4K displays simultaneously, three 5K and up to one 8K display. I took a CPU (the 2700X) which can handle all the streams with no problems.
PCPartPicker Part List: https://pcpartpicker.com/list/gd3Dk6
CPU: AMD Ryzen 7 2700X 3.7 GHz 8-Core Processor  ($164.49 @ Amazon)
Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard  ($149.97 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  ($79.98 @ Amazon)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($129.99 @ Amazon)
Video Card: AMD Radeon Pro W5700 8 GB Video Card  ($793.49 @ Amazon)
Case: Corsair SPEC-06 ATX Mid Tower Case  ($84.99 @ Corsair)
Power Supply: Cooler Master MWE Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($78.36 @ Amazon)
Total: $1481.27
Good luck and cheers!
CPU: AMD Ryzen 9 3900X | Motherboard: ASUS ROG Crosshair VIII Formula | GPU: AMD Radeon RX 6900XT | RAM: 2*16GB 3200MHz 14-14-14-34 G.Skill Trident Z Royal Silver | SSD: 2TB Gigabyte Aorus Gen 4; 500GB Samsung 860 EVO | CPU Cooler: Corsair H115i RGB Platinum | PSU: Corsair AX850 | Case: Corsair Crystal 680X | Monitor: Eve Spectrum 4K | Keyboard: Logitech G513 Romer-G Tactile | Mouse: Logitech G502 Lightspeed
https://linustechtips.com/topic/1150905-need-help-for-a-build/#findComment-13263054
