I just built my PC, and one issue I'm having right now is that dual channel ram isn't working. If I put the ram sticks for dual channel, the PC doesn't post on my monitor. The system runs, and everything. It just doesn't show anything. If I put the rams in single channel, then it works. I have Asus Prime X470 Pro Mobo, and G.Skill Trident Z RGB ram. I'm not sure what to do and my friend isn't sure what is up. Can anyone provide me a checklist so that I can test it on my build, and see what is the issue?
https://linustechtips.com/topic/1150422-need-help-figuring-out-what-is-wrong/
Install one memory stick into slot A1 (next to the cpu)
Then
Clear cmos.
Update bios.
Clear cmos again.
Boot for functionality (all the way to windows)
Shut down.
Install memory sticks into slots A2 and B2 (second and forth from the cpu) ** Try this first if you haven't already**
Try to post.
Specs?
Mhz RAM?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
