I have a 7950 running at 800 mhz, it typically mines at 400 mh/s. This is much lower than the 550 mh/s stated on the mining hardware wiki page. I'm using the bitminter mining client. Does anyone have an idea why its mining so much slower, or is this a typical speed for my card.?
https://linustechtips.com/topic/11495-low-mega-hashes-with-7950/
I have and 7970 and i get arround 630-660 mhash/s
add this on the "Extra flags:" and see if it helps "-v -w 256"
Corsair 500r White - Sabertooth 990FX - FX8150 @ 4.6Ghz - Gskill Sniper 1866 - XFX Double D 7970
Creative Recon3D Fatal1ty - OCZ Vertex3 120GB - WD Black 2TB - Ultra X4 Modular 850w PSU
https://linustechtips.com/topic/11495-low-mega-hashes-with-7950/#findComment-122773
Well that's very low. I use cgminer for litecoins, but that's just adding --scrypt in front of it. I will get my numbers for you so you can get around 630ish
My .bat file in the cgminer folder:
cgminer.exe -o poolurl:port -u workername -p workerpassword -I 20 --shaders 1792 -w 256 --lookup-gap 2 -g 1 --thread-concurrency 21712 --gpu-engine 1050 --gpu-memclock 1600
As you see I'm overclocking the memory over the max setting in afterburner, but it mines 24/7 stable @68C with fans on auto (3000 currently) I am using a Sapphire 7950 3GB with Boost
I first got an error, but I fixed it with this command in cmd:
setx GPU_MAX_ALLOC_PERCENT 100
MSI GT70-One-899NL | i7-3630QM | Nvidia GTX675MX | 12GB 1600mhz ddr3 | 128gb mSata ssd | 1TB hdd | 17.3 Full HD non-glare | Killer E2200
https://linustechtips.com/topic/11495-low-mega-hashes-with-7950/#findComment-125829
What software are you using to mine? Do you know where I am supposed to go in the bit minter client to add that?
I use GuiMiner
https://linustechtips.com/topic/11495-low-mega-hashes-with-7950/#findComment-127164
