I was playing battlefield 5 and my screen went blank.
The issue is not with the display as i connected the pc to another screen and didnt work. Both display port and hdmi give no display.
Opened the case, and the graphics card fans dont run on booting. They used to before.
The last thing i can check if the power supply cable to gpu not working. Everything else seems to be working.
Is it safe to assume that the issue is with the graphics card? Is anything else i should check.
powercolor red dragon 5700xt on x570 motherboard with r5 3600, 16 gb ram.
https://linustechtips.com/topic/1149322-help-graphics-card-stopped-working/
PSU?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
3 minutes ago, rishabht said:
psu is powering up everything else, motherboard is working fine (based on rgb light in mb and ram). could only 1 particular socket or cable in psu be at fault.
LOL, i mean what PSU do you have.......
4 minutes ago, rishabht said:
corsair rm850 2019
You have a decent PSU, don't think it's from there.
If you checked everything as you said, them it might be the Pcie connector, or the GPU itself.
Try the GPU in another PC, if you can.....
