1 minute ago, skipiebipy said:
I'm new to building my own pc
I'm trying to go cheap so my wallet doesn't die of hunger, is a wattage of 144 fine?
144w ?
For what specs?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1148795-pc-power-supply/#findComment-13244110
i already have a hard drive
https://linustechtips.com/topic/1148795-pc-power-supply/#findComment-13244116
What do you plan to use this PC for?
https://linustechtips.com/topic/1148795-pc-power-supply/#findComment-13244134
Instead of this setup I would invest like $20 and get that ?
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor $84.99 @ Amazon
Motherboard MSI B450M PRO-M2 MAX Micro ATX AM4 Motherboard $74.98 @ Amazon
Memory Patriot Viper 4 Blackout 8 GB (2 x 4 GB) DDR4-3000 Memory $39.99 @ Amazon
Power Supply Corsair CXM (2015) 450 W 80+ Bronze Certified Semi-modular ATX Power Supply $39.99 @ Newegg
Keyboard HP K1500 Wired Standard Keyboard $6.99 @ HP
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $266.94
  Mail-in rebates -$20.00
  Total $246.94
  Generated by PCPartPicker 2020-01-24 23:18 EST-0500
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1148795-pc-power-supply/#findComment-13244146
That seems much better but don't I need a CPU cooler
No. The cpu cooler which comes with Ryzen is good enough to keep your cpu temps nice. Specially that you not buying high end cpu which heats up more. This will easily do.
The problem with your previous build was that you investing money into old and basically dead platform. Ryzen is very good and will give you much more performance for basically same price (check the difference in mobo prices) . If you want to save few extra $ you can go with a bit cheaper mobo as well
                                          WHIRO
https://linustechtips.com/topic/1148795-pc-power-supply/#findComment-13244158
