I have a corsair 200r compact ATX case,
I need to order filters,
What size magnets filter fits the top?
Whta size for sides? Use 1 or 2?
Internally at the bootom i need 1 120mm
The rear exhaust  fan does it need a filter?
And on the back under the fan the is a rectangle open with vents do the sell a filter for it
Can you please help need a safe place to order from and the mag filter sizes pls
https://linustechtips.com/topic/1148317-need-filter-help/
https://www.demcifilter.com/demciflex-magnetic-dust-filter-for-corsair-carbide-200r-dust-filter-kit
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1148317-need-filter-help/#findComment-13241227
59 minutes ago, Ajs420 said:
Is that available in Canada?
I’m not 100% sure but I found this exact kit available in UK so maybe you can find it in Canada as well.
                                          WHIRO
https://linustechtips.com/topic/1148317-need-filter-help/#findComment-13241580
