AMD Ryan 7 3700x gpu
Asrock steel legend x570
MSi RTX 2080 ti gaming x trio
Cooler master elite V3 600w (integrated to case)
Corsair vengeance lpx 3200 mhz
When powered up, all RGB turns on and all fans are on however, gpu post error light turns on and tgere all is no visual output to monitor.
Both necessary 8 pin connectors are properly fitted into card, Card is plugged into PCIE slot 1
We have removed and put the battery back in twice, re seeded the gpu 7 to 10 times (no cap fr fr on god)
Any help is appreciated
https://linustechtips.com/topic/1147813-graphics-card-post-error/
It may sounds stupid but is the hdmi (or whatever cable you using) connected to gpu or mobo??
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
23 minutes ago, The_Big_One said:
Connected,swapped twice and monitor swapped
You may want to try other pcie slot.
                                          WHIRO
