XTU Benchmark. Need Help.
Go to solution Solved by Meganter,
7 minutes ago, Ev3NNN said:
Okay, but will it have any compatiblity issues on my motherboard as i have Gigabyte GA-H110M-S2  and the GPU is OC edition?
Yes it will work :)
Seems quite bad, help.
Specs:
Processor - Intel Core i5 6500 LGA1151 Socket 3.20GHz
Motherboard - Gigabyte GA-H110M-S2 Socket LGA 1151
RAM - HyperX Fury 4GB DDR4 (2)
Graphic Card - ZOTAC GeForce GTX 1050 Ti mini, 4GB GDDR5
Cabinet - Cooler Master Elite 311 - Mid Tower
Power Supply - Cooler Master B500 500 Watts
Monitor - LG 24GM77 24" Gaming Monitor, 144Hz Refresh Rate
https://linustechtips.com/topic/1147489-xtu-benchmark-need-help/
I am playing CS:GO at 144HZ refresh rate but the performance is not upto the mark.. what i can do to resolve this?
Quote if you want us to see you answered.
How much FPS do you have ?
You need more ram, a better GPU, a better CPU.
180-200 FPS max.
Also m playing 4:3 Stretched resolution (1280*960)
but i often encounter fps drops to 80 or somtimes 30 too :(
6 minutes ago, Ev3NNN said:
180-200 FPS max.
Yep you will need a new CPU, GPU and more ram because 180-200FPS at 4:3 1280*960 is a really low.
Also seeing the case and GPU, you are probably thermal throttling :
https://www.techspot.com/article/1638-what-is-thermal-throttling/
Actually i am tight on budget and upgrading my whole computer is practically impossible for me now as PC parts are expensive here in my country (India). But i was planning to get a 1660-TI  graphics card and upgrade my Intel stock cooler to lower the temperature of my CPU (max. by July or Aug this year). Will it help me to improve my CPU and GPU performance?
FOr the CPU yes, for the GPU it depends which one you get, you should look at the gigabyte gaming OC with 3 fans for example. Also a case with better airflow will be nice too.
As i mentioned in my previous post, i am planning to upgrade my GPU to 1660-TI (6GB DDR6)
https://www.amazon.com/ZOTAC-GeForce-192-bit-Graphics-Compact/dp/B07NMWQXLR/ref=sr_1_1?crid=3RXPFWE7DCSEJ&keywords=zotac+1660+ti&qid=1579595044&sprefix=zotac+1660%2Caps%2C341&sr=8-1
The link i provided is just for reference, but i am going to buy this from a local dealer.
Yes and I advised to get a better cooled GPU, this Zotac is meh at best especially in hot climate like India.
Oh, i see. Then definitely i will look after this point :) Thank you.
Actually i have a budget of $300 for my GPU, do you have any good suggestion for my current build.
You could get https://pcpartpicker.com/product/DdbCmG/gigabyte-geforce-gtx-1660-super-6-gb-gaming-oc-video-card-gv-n166sgaming-oc-6gd it's almost the same performance as the 1660Ti
