I bought I laptop 2 years ago and ready to upgrade. It isn't flashy in the slightest and I find the most annoying thing is that youtube gets stuck loading frequently, I have 150mbs internet so I don't think that is the issue, since I will be getting a new laptop what specs should I be looking at so that doesn't happen or at the very least, it happens less often.
https://linustechtips.com/topic/1147340-dumb-tech-questions/
Make sure it has a large capacity SSD, preferably 500GB but no less than 250GB
Desktop benching:
https://linustechtips.com/topic/1147340-dumb-tech-questions/#findComment-13231880
4 hours ago, Misly said:
I would recommend a laptop with a ryzen cpu as they're more bang for the buck than intel, and something like a 1660 for the gpu should be good for most tasks like gaming.
I hope this helps
that only applies to 4000 series Ryzen CPUs, older ones are still inferior if you dont need their iGPU for performance
Desktop benching:
https://linustechtips.com/topic/1147340-dumb-tech-questions/#findComment-13232343
I am not sure what I need, I want to start creating content for youtube and I do light gaming. I like playing fortnite, call of duty, and city skylines, which I currently play on my console. On steam I play some pretty old games, pac man/ arcade style games.
and what is the price I should be shooting for as far as price?
https://linustechtips.com/topic/1147340-dumb-tech-questions/#findComment-13232356
Then you're better off with Intel CPUs, unless you dont plan on buying it until about 3 months later when Ryzen 4000 series is widely available on laptops
Price depends, $1000 should be enough if you dont mind a plastic and somewhat thick laptop
Desktop benching:
https://linustechtips.com/topic/1147340-dumb-tech-questions/#findComment-13232394
