Reboot and select proper device!! "HELP"
Morning Gentlemen!
I just put together my new build the other day.
for the last 3 days i've tried to solve this dumb problem " Reboot and select a proper boot device, and press any key" this error is making me go mental.
I've read on the internet unable to find a proper solution.
I'm trying to reinstall windows 7, however it wont let me boot from anything other then my HDD.. so it boots straight
in to my desktop, when i change boot order.. nothing happens still boots to my desktop "starts normally" if i disable my HDD, and select my USB or CD with windows 7
it basically gives me this error "Reboot and select a proper boot device, and press any key"
I've tried
removing all Sata cables. plug them in, into different ports etc.
Changing USB port..
Messing about in bios..
"Mother board"
GIGABYTE Z87-DS3H
I'd truly appreciate any further assistance! thank you gentlemen.
https://linustechtips.com/topic/114567-reboot-and-select-proper-device-help/
Since i haven't had real experience with BIOS. how do i reset my BIOS?
load default settings or something like that. maybe this will fix it couse thats odd. are they proper made(boot usb or cd) not only copy-paste?
couse thats how it sounds like
Edited by s3ns3
I simply copied the files from the CD to my USB, that might be the issue? however i've got a legit serial code for my windows 7 ultimate, but i had to copy my fathers Windows 7 copy due to that fact i lost mine.. stupid me`..
Not sure what you mean exactly when you say "proper made" like a software that creates a "Proper copy" or.. i'd appreciate being pointed in the right direction here gentlemen! thank you!!
