so I have windows 10 don’t know if it has anything to do with this but, so I have a 1tb HDD and I wanted to start my pc fresh so I wiped my drive right with command prompt I believe and then I got my windows 10 from my USB to reinstall but my pc is always now just black screen, now that I think about it I feel like I remember a message popping up saying the drives manufacturer files will be deleted, also my pc never used to turn off via the little windows icon at the bottom left instead I always have to manually press the power button.
https://linustechtips.com/topic/1145080-hard-drive-issue/
Try reinstalling windows, make a fresh copy of w10 , create bootable drive (use rufus he will show you if there is any problems with your iso file)
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1145080-hard-drive-issue/#findComment-13213325
