Hey guys. I have a master liquid ml240l RGB. it is aura sync ready how ever my z390p motherboard from Asus is not. it only has a 4 pin RGB header. Aura Sync is basically not detecting the RGB AIO. is there any way I can make the aio sync? my RAM and graphics card are being detected so I have no issues there.
https://linustechtips.com/topic/1144788-need-help-with-aura-sync/
Did your ML20L come with the light controller?
EDIT: The wireless LED ARGB Controller? Mine did, and it doesn't connect through the RGB Ports at all. I believe it connects via USB 2.0 and is software controlled.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
6 hours ago, NickoMate said:
@Statik oh shit. I just realised I plugged the controller into the included case fans because they both have the same header. now the front fans are breathing and the controller is working with the AIO. Cheers mate
There’s a special place in hell for LED controllers. They’re a pain in the ass
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
