I just built my new gaming computer with the following specs:
- Ryzen 7 2700x
-Asus ROG x-470 Motherboard
-16 GB Corsair Ram 3200 Mhz
-Corsair Hydro Series, H115i RGB PLATINUM
-GIGABYTE GP-G750H 750W
- Radeon RX 570
I have been experiencing the following issue, every time I power on the computer everything turns on and then turns off after 2 seconds and then it powers on again and remains on until I power it off.
https://linustechtips.com/topic/1143405-computer-will-not-turn-on-properly/
Greetings @SharkJaw,
               I am assuming that the issue you are encountering is that there is nothing displayed on screen after attempting to power up the computer.
               Some troubleshooting steps that may help:
               1) Try plugging the monitor into different ports on the graphics card.
               2) Try plugging the graphics card into different ports of the monitor and changing the input in the monitor settings.
               2) Try removing the graphics card and plugging into the motherboard display connector.
               3) Try removing each stick of RAM, then attempting to boot with only one stick of RAM, ensuring that stick is inserted firmly until it 'clicks'. Try that stick in each slot, then switch out for another stick and try again.
               Let us know if these steps result in any different behavior.
