Sort of newbie here seeking help..
I got myself a hand-me-down motherboard and figured i should build a pc onto it. Ordered one Rx580 and a 3570K with 16 ram.
So the question part: My mobo is a Gigabyte GA-H61-DS2 rev 2.0 currently on BIOS version F3.
The official page shows tha latest version is a Beta F10a which adds higher end Gpu better support. Should i trust the beta BIOS  and update it (It's my first time ever doing such thing) or pick the F9 since that seems more sure to work.
https://linustechtips.com/topic/1143368-help-apriciated/
3 minutes ago, boxrr said:
One more, do i install the F10a from the beginning or do i need to install each and every one after one?
I would advise not to get that beta bios. In many websites it’ll tell you that you basically flashing the board at your own risk, for instance this is beta bios for my board
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1143368-help-apriciated/#findComment-13199752
