Hey Guys, So My Problem is that I get Bluescreens so often the Pc is unusable. One Time every 10 Minutes.
I Got an Ryzen 2600(stock), MSI  x470 Gaming Carbon(already fixed), 32 Gb of Gskill 3000mhz.(2933mhz xmp). WIN 10 64bit. 1000W Platinum Corsair power supply. Asus 1080 Advanced gaming.
These 2 Files ntoskrnl.exe, envirtahci.sys often come up in bluescreenview.
Can somebody help me? Is it Software or Hardware? The Ram survived some hours of Memtest when I build the pc. even on custom settings back then.
bluescreen.txt
https://linustechtips.com/topic/1143248-randomrepeating-bluecscreens-help/
Do you ever get boot loops when you try and power on?
1 minute ago, Stu_Bear said:
Are you running any memory tests while this happens?  Are you getting blue screens with the system idling with nothing running?
also crashes while idling.
no
If all else fails...reinstall windows and NOT install anything else...test ur pc out, but don't download testing software to do so...just use it.  Then add updates/patches for MS and Nvidia only.  Also, try using the default settings in BIOS...
3 minutes ago, Stu_Bear said:
yeah storemi is installed but not setup... WIll try to deinstall it
does putting a load on the system always result in crash?
no, random as I said cant force it in any way just happens
11 minutes ago, Jaxzzzzz said:
have you tried re seating the CPU in the socket
Ye just rebuild everything.
16 minutes ago, Stu_Bear said:
Well, I think there's still a driver left. Dont know if I should also just disable that. Never set up storemi
Like i was suggesting...a fresh install of Windows 10 "should" blow out any hiding gremlins if it's software related.  I'd even go so far as to be certain the drive you reinstall on has been formatted.  Can't remember if windows 10 gives you the option to format when installing/re-installing.
Disabling the leftover driver breaks everything great. I don't want to reinstall win 10 arghghghg. Not another Time.
