Check the motherboard manufacturer website for a new bios update and a change log. They may have upgraded the bios to make the board compatible with polychrome. You can also contact them directly and see what they have to say on the subject.
Ryzen 7 3700X
Aorus GTX 1080ti
G.Skill TridentZ 3200MHz 2x8GB
Corsair SFX 750W
Phanteks Evolve Shift Air (glass front)
2x Corsair Force GS 120GB SSD (RAID 0)
https://linustechtips.com/topic/1143221-need-help-with-rgb/#findComment-13199829
