Guys I need help I currently have a 1TB WD blue HD and a 120GB SSD which I have windows installed on, and I don’t feel like I have enough storage if I get an 240 GB m.2 SSD can I move windows to the m.2 drive and run all 3 drives
and also what is the best M.2 drive I can buy for around $60/ £50
https://linustechtips.com/topic/1142492-drives-help/
3 minutes ago, ToastyBear said:
You can use software to clone the 120GB SSD onto the new M.2 SSD and then just wipe it clean to use as storage or something.
I'm assuming the question is what model/size of SSD is recommended to swap 120GB SSD..
OP, NVMe, M.2 SATA?
Pax vobiscum
https://linustechtips.com/topic/1142492-drives-help/#findComment-13192317
