I’ve spent ages on trying to work this out and haven’t had any success and decided to come on here to see if anyone intelligent or an expert on pcs will help me aha. I’ve built my first pc and I finally got enough parts to what I think is enough to turn it on, I’ve got my cpu, gpu, ram, motherboard, case fans, power supply and all the correct cables linked up in my case all supposedly working. (Except a Cpu fan)
When I press the power button the computer turns on for 10 seconds before turning off for 5 and booting up again, this continuously happens until I pull the plug, this only happens when my cpu isn’t but as soon as I try turning it on with my cpu in it turns on for 2 seconds instead of 10 and immediately turns off again ,but this time it might only try one more time not loop itself before, not even showing any response other than the green light on my graphics card before me having to unplug it and replug it or switch the switch on the power supply on and off.
Someone please help me it would be greatly appreciated thanks x
https://linustechtips.com/topic/1142275-help-me-with-my-pc/
Can we get the specs of your PC? It sounds like you are having a boot loop and in this case it could be a motherboard or CPU, going by the fact the GPU is getting power and is powering on, Im going to assume the GPU and PSU are fine. It could also be a CPU and Motherboard incompatability, even if the socket is the same for both, some motherboards depending on their chipset need a bios update to function
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190227
Motherboard : GIGABYTE GA-H110M-DS2
Cpu : i5 - 2460
RAM : stick 1 is 4GB of hyperx
           stick 2 is 4GB of ballistix
GPU : ASUS 740 I’m not sure on this
and my power supply is fine
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190258
Cpu : i5 - 2460
Is that CPU correct because I just googled that model and cant find it.
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190261
Yep after seeing the video there is defo something shorting it, if you say it stays on for longer when you take the CPU out, imma guess its that. if you could check the cpu name again, that would help though
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190270
Just now, JxmieTech said:
It’s a 2400 sorry it’s hard to read aha
Yes how will I fix that it’s so annoying I just want to get it working
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190285
The 2400 is a 2nd gen cpu, the motherboard you have gotten is a h110 which is for 6th gen. they are completely different. They have completely different sockets, the 2400 is LGA1155 whereas the h110 is LGA1151. There is no fix, they are incompatible with eachother
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190294
Honestly im kinda surprised it didnt just poof into a ball of magic smoke, with the pinouts being different. Thank god you have an asus psu otherwise this pc would have been dead, I still think you have royally killed that CPU, and potentially the motherbaord socket, but we can hope at least one of them survived
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190322
Ohhh ok thanks so much aha silly me
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190325
Is their anyway I can find which ones dead so I don’t waste money on one that’s ok
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190331
pcpartpicker is very useful for things like this
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190333
15 minutes ago, JxmieTech said:
So?
oh sorry i thought you meant how you would check incompatibilities
the only way in this scenario is to get another compatible motherboard or cpu and switch them out
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190399
Just to check all the pins in the motherboard look good right?
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190469
Surprisingly that socket looks ok, cant tell but looks like you might have damaged the black plastic in the top right of the picture.
As the i5-2400 is LGA1155 it doesnt physically fit in the LGA1150/1 sockets, so luckily you cant really crush the pins. Did you damage the CPU? Pretty sure you would have had to to get that retention bracket down....
So for a CPU compatible with that board, probably get a i5 7500
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13190499
No it’s fine but has some marks on the side showing stress I think the motherboards ok so I’m going to purchase an i5 7500 now so it’s compatible with my h110 chip set on my motherboard
https://linustechtips.com/topic/1142275-help-me-with-my-pc/#findComment-13193242
