So, I'm currently planning on starting to buy parts in the next couple days, and I've got a decent idea on what parts I want
I want some inputs on this build, because its better to make a decision with different points of view
PCPartPicker Part List: https://pcpartpicker.com/list/Zhmqb8
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($194.99 @ Walmart)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($31.99 @ Newegg)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.99 @ B&H)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 Memory  ($149.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($114.99 @ Newegg)
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB BLACK GAMING Video Card  ($474.98 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($84.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Best Buy)
Total: $1276.91
Generated by PCPartPicker 2020-01-04
1. Budget & Location
My budget is around the $1200 - $1300 USD
2. Aim
Currently, is for some editing, multitasking and gaming
3. Monitors
Currently, I have 2 monitors (one 27" 1080p and a 21" 720p as a secondary), but I'm planning on adding a third 144hz 1080p monitor in the future (and of course, making it my main)
4. Peripherals
I won't be needing new peripherals, but I will be needing windows
5. Why are you upgrading?
upgrading from a pre-build because there's barely room for any upgrades without having to build everything from scratch and I want a computer that's gonna last for a good amount of time and with room for any upgrade.
I also want to do some gaming without my computer choking with 100% CPU usage and RAM usage
P.S.: anyone know some decent 144hz monitors around the $200-$250 USD range?
https://linustechtips.com/topic/1141780-help-with-new-pc/
change RM to RMX or even better TXM ( corsair line ). i heard sabrent roket is better than intel.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1141780-help-with-new-pc/#findComment-13186228
The cpu has an included cooler that isn't much worse than the 212. If you want a significantly cooler and quieter cpu, invest in a noctua or be quiet or scythe, otherwise, stay with the stock cooler.
The hp drive I linked is much faster than the intel one. Also the memory sweet spot for ryzen 3000 series is 3600MHz. I pick a kit with tighter timings (c16).
The motherboard is roughly the same, but cheaper.
A 550w psu would be enough for your system, i put a 650w one in in case the next gen gpus from nvidia are power hungry.
https://linustechtips.com/topic/1141780-help-with-new-pc/#findComment-13186518
660p is fine.  Its actually way faster for gaming than most other SSDs when it can use the intel smart caching.  It's a QLC with an SLC cache so it runs about as fast as an SLC drive for gaming and most editing loads.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1141780-help-with-new-pc/#findComment-13186609
I got a question on this, is it worth considering a x570 chipset rather than a b450? was looking at some discussion and b450 is good but they said that x570 has more room for upgrades in case I ever want to go beyond ryzen 5
and does b450 support 16gb sticks of 3600MHz?
https://linustechtips.com/topic/1141780-help-with-new-pc/#findComment-13187553
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($322.99 @ SuperBiiz)
Memory: GeIL EVO POTENZA 32 GB (2 x 16 GB) DDR4-3000 Memory  ($94.99 @ Newegg)
Storage: PNY XLR8 CS3030 1 TB M.2-2280 NVME Solid State Drive  ($114.99 @ B&H)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  ($79.99 @ Best Buy)
Power Supply: Cougar GX-S 550 W 80+ Gold Certified ATX Power Supply  ($73.98 @ SuperBiiz)
Total: $1276.91
Generated by PCPartPicker 2020-01-04 21:57 EST-0500
https://linustechtips.com/topic/1141780-help-with-new-pc/#findComment-13188231
A good b450 will work even with a 3900x and definitely supports 16gb sticks. However, we don't know what ryzen 4000 series will bring and it's more likely that it will work better with x570 boards. A year ago, when good x570 boards were $200+, I would have recommended the $100 b450. But now that the very good asus x570 boards are $150 or so, I recommend them for future upgradability.
https://linustechtips.com/topic/1141780-help-with-new-pc/#findComment-13188659
