Hello,
I tried OCing my 2400g to 3.9Ghz but i have some doubts regarding its voltages. I have attached the screenshots.
In bios I have set the offset to -0.072 and it shows in bios as 1.368v in easy mode but in system it shows higher voltages.
Anyone can help me with the true voltages are and if they are safe at all?
CPU: Ryzen 7 5700X Undervolted  Motherboard: B550 Aorus Elite V2 Rev1.2 RAM: G.Skill TridentZ Neo 3600Mhz CL16 32gb
GPU: MSI Mech 2X RX6600 8GB Cooler: ProLab Design AI360 LC AIO Storage: WD SN770 500gb + Sn550 1Tb + MX500 1Tb + 1TB HDD
PSU: Antec EAG Pro 750 80+G Case: Deepcool CG580 WH Monitor: Benq Mobiuz EX2510 144Hz
Mouse: G Pro Wireless Keyboard: Corsair K68 RGB Cherry MX Red Speakers: Creative Pebble V2
https://linustechtips.com/topic/1141452-2400g-oc-need-help/
Also does minusing offset lower or increase voltage?
https://linustechtips.com/topic/1141452-2400g-oc-need-help/#findComment-13183624
If I'm recalling correctly, 1.35v is the max for the 2400g. When I OC'd mine, I didn't mess with 'offsets' as I really don't understand what it's doing. I simply lowered the CPU voltage. Right now I'm sitting at 1.31v @ 3.8 ghz on all cores.
See if you have a setting to lower the CPU voltage.
https://linustechtips.com/topic/1141452-2400g-oc-need-help/#findComment-13183856
Nope, I only have the offset. I will try with -0.085 tomorrow to see if its stable.
https://linustechtips.com/topic/1141452-2400g-oc-need-help/#findComment-13184024
