In task manager, my RAM speed indicates it's running at half of the speed I have it set to in the BIOS, regardless of the speed. I also notice stuttering games, presumably because of this.
I did recently upgrade my GPU (RX 580 to 2060 Super) but idk if that had something to do with it?
Specs
Ryzen 5 1600X 3.7GHZ
G.Skill TridentZ RGB 2x8 DDR4-3200
EVGA XC Ultra RTX 2060 Super
ASUS Strix B350F
https://linustechtips.com/topic/1140893-ram-speed-problem/
Check with CPU-Z, should say 1600 (because data rate is double the actual clock)
Desktop benching:
https://linustechtips.com/topic/1140893-ram-speed-problem/#findComment-13179184
