Because of my constant travelling between parents i need to have a small PC that can run decent ish games with a portable monitor here is what i have got im using vega 11 graphics but would like to upgrade in the future my only question is will the motherboard support the CPU as i ideally need a wireless connection im using this motherboard any suggestions?
With something like this as a portable monitor.
https://www.ebay.co.uk/itm/Portable-15-6inch-Screen-1920x1080-HDMI-Monitor-For-PS3-4-Xbox-360-Raspberry-Pi/303400187611?hash=item46a40f76db:g:zqsAAOSw1Upd8f5w
https://linustechtips.com/topic/1140626-portable-pc-build/
the core V21 is actually pretty big IIRC, pick up something like a coolermaster elite 130 or silverstone sugo instead. you may need to update the BIOS on the board but otherwise it'll work.
https://linustechtips.com/topic/1140626-portable-pc-build/#findComment-13177116
worse CPU but much better GPU:
PCPartPicker Part List
CPU: AMD Ryzen 3 1200 3.1 GHz Quad-Core Processor  (£44.00 @ Amazon UK)
Motherboard: ASRock AB350 Gaming-ITX/ac Mini ITX AM4 Motherboard  (£92.98 @ CCL Computers)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  (£52.98 @ Box Limited)
Storage: Patriot Burst 480 GB 2.5" Solid State Drive  (£42.27 @ Ebuyer)
Video Card: Gigabyte Radeon RX 570 4 GB Gaming 4G Video Card  (£109.99 @ CCL Computers)
Case: Cooler Master Elite 130 Mini ITX Tower Case  (£39.97 @ Amazon UK)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  (£44.99 @ Amazon UK)
Total: £427.18
Generated by PCPartPicker 2020-01-01 13:45 GMT+0000
https://linustechtips.com/topic/1140626-portable-pc-build/#findComment-13177126
Total: £427.18
A fractal design node 202 would probably be the most portable due to it's slim design.
https://linustechtips.com/topic/1140626-portable-pc-build/#findComment-13177133
Total: £427.18
this is probably the best but is 2200G is option-able? i meant ti has betterboost clock.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1140626-portable-pc-build/#findComment-13177155
Total: £427.18
Personally i really dont like the cool master case would mine still fit with that motherboard?
https://linustechtips.com/topic/1140626-portable-pc-build/#findComment-13177228
Sure, but it's pretty big as i said. Maybe take a look at the core V1 instead, it's mostly just an M-itx variant of the core V21.
https://linustechtips.com/topic/1140626-portable-pc-build/#findComment-13177449
