I hot swap a lot of 2.5 and 3.5 inch disk and I never use more than 2 hot swap disk at the time. I am looking foward to accelerate my hot swap process without connecting those disk manually with cables in my case. I have 2 free 5.25 inch bay available on my PC case. I was thinking of getting a 3.5 to 5.25 enclosure (2x) and a 2.5 to 3.5 enclosure (2x) that way I have the possibility of having a mix of 3.5 and 2.5 disk in the PC as hot swap devices.
My question is the following: does StarTech 25SAT35HDD fit inside of StarTech HSB1SATSASBA ?? I am not exactly sure since the 2.5 to 3.5 enclosure is just a bit bigger than a normal 3.5 hdd.
If it doesn't fit do you know which 2.5 to 3.5 enclosure would fit in the 3.5 to 5.25 enclosure ? (No screw, only clip, slide or whatever that require no tool at all)
https://linustechtips.com/topic/1139490-does-it-fit/
