what's your performance target? is the use case mostly gaming?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1139485-i-need-help/#findComment-13168471
The 1060 3gb would pair with a 2700x perfectly fine. If you had a weaker cpu like 2600 and got a 2080 ti then a cpu upgrade would be needed because you would need a faster cpu to send data fast enough so that the 2080 ti could run at its max potential. If i were i would upgrade the gpu just because the 1060 3gb isnt that fast of a gpu anymore by todays standards because of games getting harder to run. And a great price to performance and feature set motherboard is the MSI B450 Tomahawk if you are sticking with ryzen, it goes for about $115 and its a very robust option if you dont want to break the bank.
https://linustechtips.com/topic/1139485-i-need-help/#findComment-13168480
5 minutes ago, Relly04 said:
Yes just for gaming i just want a solid gaming experience for csgo, fornite, lol, r6, GTV ect
you could go cheaper and get yourself a Ryzen 5 2600 instead
Primary PC:
PSU tier list
https://linustechtips.com/topic/1139485-i-need-help/#findComment-13168499
