Help choosing RAM
Go to solution Solved by Whiro,
20 minutes ago, Camax111 said:
Speed or amount? For streaming, gaming, video editing, and multi-tasking
I got a ryzen 5 1400 but intend to change to a 3900 or a 3950x from ryzen 9 series
I would go with 2 x 16gb, and higher speed , at least 3200 or higher.
With Ryzen it is best to use 1 stick per channel (Ryzen supports dual channel). This is because you will likely have to lower speeds and/or loosen timings in order for them to work. For example, 2 sticks might get 3200, but 4 only 2666.
I have been thinking of buying a ram upgrade for my pc
My motherboard is a
motherboard link ROG STRIX B350-F
https://www.asus.com/us/Motherboards/ROG-STRIX-B350-F-GAMING/
And I've checked the QVL list and I'm down to 2 options that I could find available
32gb at 3000mhz CORSAIR DOMINATOR Platinum Series 32GB (2 x 16GB) DDR4 DRAM 3000
https://www.amazon.com/gp/aw/d/B016BWENUI/ref=ox_sc_act_image_1?smid=ATVPDKIKX0DER&psc=1
Or 64gb at 2400mhz G.SKILL 64GB (4 x 16GB) Flare X Series DDR4 PC4-19200 2400MHz
Memory Desktop Memory Model F4-2400C15Q-64GFX
https://www.amazon.com/gp/aw/d/B071D9XB26/ref=ox_sc_saved_image_1?smid=A1YAK8U7QV5H1E&psc=1
https://linustechtips.com/topic/1138976-help-choosing-ram/
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1138976-help-choosing-ram/#findComment-13164828
