advice First Build
Only possible tweak with that tight of a budget I tried making. Made the motherboard a really good one for VRMs and future upgrading, and it supports this newer Ryzen APU. That said, I dropped the storage a bit but I hope you have a HDD you could pop in for raw storage. Otherwise your next upgrades would be that and a dedicated GPU to really get more from games, but at least this Ryzen is Zen+ so by comparison to the 2400G it has slightly faster cores (and higher base clock):
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor ($189.75 @ Vuugo)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard ($99.99 @ Mike's Computer Shop)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3000 Memory ($59.99 @ Canada Computers)
Storage: Kingston A400 240 GB 2.5" Solid State Drive ($34.99 @ Amazon Canada)
Case: Corsair SPEC-05 ATX Mid Tower Case ($34.99 @ Canada Computers)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply ($54.99 @ Memory Express)
Total: $474.70
Generated by PCPartPicker 2019-12-25 18:22 EST-0500
