I just build my new gaming pc yesterday and it went great, but after i had installed windows, drivers and some programs it started freezing after startup. When i restart the pc it happens 3 times in a row until a blue screen appears and says that their have been a problem, so it does some kind of repair restart and then it works until i turn it off. I dont know whats causing this problem, i have seen someone say its something with the power management, but that doesn't seem to fix it.
PC specs:
CPU: AMD RYZEN 3600x (with stock cooler)
Motherboard: ASUS ROG STRIX B450-E gaming
RAM: Gskill Tridentz 3200 16GB
GPU: ASUS Geforce RTX 2070
PSU: Corsair TX650 - 650W
Storage: Kingston A2000 M.2 ssd 500GB
I hope someone can help me, thanks in advance.
https://linustechtips.com/topic/1136806-pc-freezing-right-after-startup/
RAM perhaps.  Did you install them into the correct slots?  Have you enabled XMP?  Have you updated the BIOS?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
15 minutes ago, Rexx said:
but i haven't enabled XMP
enabled it.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
