random errors when using X.M.P on my new build
Solved by Jurrunio,
11 minutes ago, Kaltar said:sry but i dont fully understand what do u mean by that, i still have my warranty on everything, does this mean that i have a broken ram kit and the problem can be fixed by replacing the part thats damaged, or is it not going to work at full speed with this cpu no matter what i try or get ?
thanks for ur help
problem of 2nd gen CPU's memory potential, they are just no good for 3600MHz
