What is the benefit of using them? I had many problems with them like: mic not picking up, audio signal is glitchy and some other minor ones. I deleted the drivers and now my audio doesn't glitch or has problems is there any reason to switch back?
Btw as you can see i'm really not knowledgeable on the subject.
https://linustechtips.com/topic/1136434-realtek-audio-drivers/
I've never had much luck with Realtek myself. If you're only doing basic things such as gaming and chatting on Discord, you're probably fine to just use the default Windows ones. I mean as long as it's working for you, no need to try and change it again. If it ain't broke, don't fix it.
https://linustechtips.com/topic/1136434-realtek-audio-drivers/#findComment-13145569
