Electric shock from case
Go to solution Solved by Akira Shimazu,
YOU are fine. god.
1 minute ago, AndeSandwich said:
So i was building a pc and i wasn't touching the motherboard or anything else electronic, but then i touched the case and got an electric shock. Did something in the pc get fried?
u sure it was Electricity? because there are times where our nerves get shocked a little bit by unknown stimulus you know. probably it just your body
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
Pretty sure because i touched the case and then it happened.
it was metal case right? in my experience everything should be seal.
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
You're fine. The motherboard standoffs act as a protector towards the motherboard.
only way to know for sure is to power it on and see if it works. we're not magicians you know, lots of variables here.
youre building PC which is i assume you havent turn it on when you get shocked?
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
Haven't had a chance to power it on yet since it is my friend's and we're finishing it on friday.
Nope. I haven't turned it on yet.
just feeling. ignored it. it just your nerve system tbh.
if its not on then how can it transfer electricity? you are fine man.
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
1 minute ago, VinZie said:
The electric shock was most likely static electricity discharging onto your case.
probably this.
if you are unlucky the static would have gone through the case, through the I/O plate, through the board and into the vulnarable CPU or something.
that probability of this happening is less than 0,0000000001% though.
boards these days are fairly bulletproof.
this also can be true which is normal. like brushing your hair with Ruler thing. 5th grade science
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
U sure? Because it was actually when i bumped my forehead into the case and then i felt what i am sure, was an electric shock.
we all feel that when we bump our head to metal.
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
Wear a wristwrap next time. Make sure it's not connected to anything and use tweezers.
Like this guy
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
hah i remember back then use to rub my feet on carpet and touch metal things the static shocks were sooo bad that can see the lighting arch when it touches. and it hurts soo bad like it was a real zap from the outlet lmao. so yes thats surely all it is if its not even plugged in yet as proof aha.
