Hey so I have recently build my very first rig, it's low level entry rig and here are the specs:
1. Ryzen 5 2600
2. Kingston 16gb 3200mhz
3. Rx580 8gb
4. B450m steel legend
5. Adata nvme m.2 512gb
6. Corsair C650M
7. Tecware Alpha M
A question from me is that will the GPU be suffocating due to the lack of airflow? Do refer to the attached picture. Any suggestions will be appreciated.
Do ignore the PSU not being plugged in I'm still waiting for it to arrive.
https://linustechtips.com/topic/1135708-airflow-issues-or-not/
plz send pic of front pannel at multiple angles
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13138940
Don't think so as the front is pure mesh. You could try checking temps when gaming or stress testing. Download Hwinfo64: https://www.hwinfo.com/download/
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13138969
Ah shit, i am at work now ahahahahah, but it's full mesh doe
Alright sure thanks alot!
14 hours ago, Geoff35674567 said:
This is fine. When you do get it running you will notice your GPU will be way hotter than your 2600. This is normal.
Ah alright, first time building a pc and kinda scared i fucked up on the measurements
11 hours ago, LogicalDrm said:
GPU will be hot, but thats more about PSU shroud than anything else.
Welp, i guess it should be fine? Ahahhaha
4 hours ago, Midnitewolf said:
Unless there is something restricting the front it should be fine.  I also don't think much you can do differently to get any more airflow to the GPU and should be good enough for the GPU to run as expected.
Aye thanks, will see how it runs when my PSU is here.
3 hours ago, Mutuh said:
You could try mounting the intake fans a bit lower.
That's a big brain move right there will try it. Thanks!
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13141090
Even with full mesh, they somehow still screw up, as for the internals, it looks absolutely stunning and shouldn’t have any issues.
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13141669
He’s at work so quick google search shows this
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13141769
Then idk why op needs to be worried, looks perfect to me in every aspect.
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13141775
Btw I really like the look of this case, unfortunately it’s not available to buy anywhere in UK, otherwise I would consider getting it.
                                          WHIRO
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13141776
Only thing which I noticed is there is another dust filter underneath the mesh.
@gavinleejia of you not happy with the temps you can always try to remove that other dust filter and see if that improve temps
                                          WHIRO
https://linustechtips.com/topic/1135708-airflow-issues-or-not/#findComment-13141789
