New System Advice
1 hour ago, Plock said:Well, I have just started Uni and I know that we have got a big chunk on games development in Unity coming up, I also have to do lots of programming in Visual Studio.
Apart from that, I occasionally do light photo editing in Photoshop and very rarely have to edit a video using Premiere. I have never streamed and don't plan to. I expect this machine to last between 4 and 5 years without upgrading it, then I will either upgrade some parts or just get a new machine.
As I have said, I only really play Minecraft and GTA5 because of the limitations of my current computer, but I like the idea of branching out and playing some new games in the future, without having to worry about if my computer can run it.
I'm not planning to overclock the system; however, I like the idea of getting more performance out of my CPU and might try it in the future. This is the main reason for getting the Strix motherboard in the first place. If you have any other suggestions for Asus motherboards, I would love to hear them.
i would go along with the other suggestion given about gigabyte boards, although if you insist on sticking to Asus for whatever reason unless you want to spend $300 for a mobo the strix is your best option. I would suggest the Gigabyte Z390 Aorus Elite its $172 so cheaper then your board and has superior vrms for overclocking. so if you want to OC in the future go with that, if you plan on never overclocking vrms dont matter too much, but its cheaper and its better to have it and not need it vs needing it and not having it yanno. If you are doing things besides gaming like you listed i would still go with a 3800x but you seem to not be comfortable with AMD and want to stick with team blue, on that note the 9700k will suit you just fine. in the 4-5th year of use it may not still hit 144hz like it does now but thats with anything, it sounds like you know what you want and just want assurance everything will be okay, im here to tell you, your system is just fine. the only real suggestions we have you arent interested in or comfortable with anyways, and the current config you have will suit everything you need, just go for it and im certain you will be happy with your build for the years to come
