I have b350 tomahawk then i have ryzen 5 2600 and ram corsair vengeance lpx 2666mhz 8x2. Ryzen needs more speed or 2666 already good for my setup?
Ryzen 5 2600 / MSI B350 Tomahawk / GALAX RTX 2060 6GB (1-Click OC) / Corsair Vengeance LPX 2666Mhz 8x2GB / ADATA SX6000 LITE 512 M.2 NVME / KLEVV 128 GB SATA / Seagate Barracuda 2TB 7200rpm / Seasonic Focus Gold 550W / Tecware Nexus C
Upgrade Plan: CPU: Ryzen 5 3600 RAM: GSkill TridentZ RGB 3200MHz/3600MHz MB: MSI B450 TOMAHAWK MAX
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/
Most will say absolutely and don't go below 3200Mhz. Because it has been pretty established that at 3000 or 3200Mhz is when Ryzen's extra performance from memory speed begins to diminish. Since you already have the 2666Mhz RAM it isn't worth to spend another 60$ or so to get a 3000/3200Mhz RAM just to replace your 2666Mhz. There are a lot of RAM Speed charts out there that I suggest you Google to find. Then you can figure out if spending is worth the difference between 2666 vs 3000/3200 for your use case.
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133003
As other said it is not worth deal with it and it will be ok, i do not agree.
It is absolutely worth getting the correct RAM of 3200Mhz to get all the potential of your PC
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133027
What is ram use? Stability or memory for multitasking like opening many app?
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133041
Are you having performance issues? Higher clocked RAM does really help Ryzen, but unless you're having issues then there's no need to upgrade.
What? Are you asking what RAM is used for?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133042
Yes, im sorry for my bad english and grammar also.
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133049
Ah, RAM is just Random Access Memory. It's much faster than any HDD or SSD, so your PC loads most apps you have open into it, so the CPU can then access it very quickly. Same as VRAM on GPUs (which is even faster), games load a lot of files into that so it can feed it very quickly to the GPU core. RAM is used for literally everything, GPU VRAM is used only for stuff that actually needs to be rendered on the GPU.
Mouse: EVGA X17
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133061
Ryzen 5 2600 rtx 2060 with 2666mhz ram should be fine right?
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133065
You're buying new or you already have it? If you already have it, you're probably fine (unless you have performance issues, depends on what you're doing and/or what games you play). If you're buying new, get 3200Mhz CL16 or 3200Mhz CL14 RAM.
Mouse: EVGA X17
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133085
Already have it, Some game had a problem with Fps. I thought this setup will have a VERY STABLE. Its my bad tho. too expected too much from my setup
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13133173
Depends on the game, some are never very stable, either due to being very hard to run, badly built, or both. What games are having issues?
Mouse: EVGA X17
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13134033
CSGO, and other game like black desert mobile. I dont know it can runs at higher settings than before. Its normal because rtx 2060 > gtx 1060 3gb. Hmmm some game like have high fps but dropped so much like 30 or 50 fps like that. But no stutter, sometimes yes
https://linustechtips.com/topic/1134984-ryzen-needs-speed-ram/#findComment-13134065
