I recently finished building my PC, using a HAF 912 advanced case, and an ASUS P9X79 motherboard. The problem I am faced with is from what I can see, the motherboard does not have any male headers for the female 3.0 header that comes with the case. I was wondering if anyone knew a way to attach the female header to the motherboard so that the 3.0 ports (on the front of the case) are usable, e.g. an adapter.  If you need any more info regarding my system, then just ask. If anyone does have a solution, that would be really great. Thanks!
https://linustechtips.com/topic/11348-usb-30-header-problems/
as said above you could convert into usb 2.0,or you could convert the usb 3.0 female on the case into usb 3.0 male connector,route it to the rear I/O of motherboard and still have usb 3.0 on the case.
like this
http://usb.brando.com/usb-3-0-20-pin-header-female-to-usb-3-0-type-a-male-short-cable_p02788c032d015.html
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/11348-usb-30-header-problems/#findComment-121360
