So I have an Intel i7-9700k, I am trying to get a stable overclock at 5Ghz. So first I stet my voltage to 1.275V and ran Prime95, immediately worker #4 and #6 gave me a rounding error and stopped working completely. The program didn't crash though so what does this mean?
https://linustechtips.com/topic/1134236-overclocking-issue/
I have the same CPU, 4.9Ghz on all cores with just Intel Turbo Boost and Multi Core Enchantment, all the rest of the settings are on auto!!! Works like a charm!
Few months ago i was also playing with OC, i set the multiplier to 50/5Ghz and no other change in the bios, just the multiplier.
It was working at 5Ghz on all cores, tested a bunch of software plus many games, everything was working just fine.
But i did not notice any major improvement and the i7 9700k is a beast by itself, so now i have it running at 4.9Ghz on all cores.
Never had any issues!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127711
Just did what you said, started running Prime95 and after 10 min one of my Worker#6 failed with a rounding error
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127723
With only 4.9Ghz on all cores and just Intel Turbo Boost and Multi Core Enchantment?
EDIT: what is ur motherboard?
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127727
Just now, Noob Builder said:
Yes, do I need to manually set 4.9 on all cores? Because I set it to auto and it stayed at 4.9
No you don't.
Intel Turbo boost with Multi Core Enchantment have this result.
No need to set anything else
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127734
OK, so where is ur problem?
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127740
1 minute ago, Noob Builder said:
Well okay, then yes it failed even with just those two on
Hmmm what is ur mobo?
Are you sure all other settings are on defaullt?
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127741
Z390 Auorus Pro
RAM?
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127745
Start from scratch,
16 Gigs of 2400Mhz ram
Your ram is to low for this set up.
It should be at least 3200Mhz!
My advise is start from scratch, clear Cmos (or remove the battery for 10 minutes with the PSU unplugged)
And set only  Intel Turbo Boost and Multi Core Enchantment.
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127758
2 minutes ago, Constantin said:
Start from scratch,
Can't afford new ram, thanks for help though!
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127763
2400Mhz  with XMP on?
If not OC the ram manually to 2600Mhz and don't touch the voltage, leave it to auto!
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127764
27 minutes ago, Noob Builder said:
Last time I OCd the ram I kept blue screening.
https://linustechtips.com/topic/1134236-overclocking-issue/#findComment-13127831
