I've been looking for a good RGB controller that suits my build but I'm not having any luck finding one, hoping I might find some more help here.
I have the following RGB things in my build:
6 x EK-Vardar EVO 120ER RGB fans
1 x EK-Supremacy Classic RGB - Nickel + Plexi CPU block
1 x EK-FC RTX 2080 +Ti Classic RGB - Nickel + Plexi GPU block
1 x EK-Classic DP Side PC-O11D G1 D-RGB + DDC 3.2 PWM distribution block
Except for the distribution block everything is the typical 12V RGB control. I have a 5V header to take care of the distribution block on my motherboard and I have an additional 2 12V RGB headers on it as well so I can take care of the CPU and GPU block with those. So that pretty much just leaves the fans. I'd prefer if the controller was compatible with PolyChrome Sync so I can have everything housed under 1 software but that's not a must. I'd also prefer individual control over the fans.
https://linustechtips.com/topic/1134113-rgb-controller/
