Audio output not there
Go to solution Solved by Soroax,
windows update solved
So randomly when I was watching youtube my audio cut out and started to play through my speakers instead of headphones, when I go to sound settings and output the audio device I want to hear from is not there but when I go to input the audio device that I want is there but I need it at output.
https://linustechtips.com/topic/1133183-audio-output-not-there/
Check the cable for the headphones hasn't came loose
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
https://linustechtips.com/topic/1133183-audio-output-not-there/#findComment-13118173
Pleased it sorted itself
https://linustechtips.com/topic/1133183-audio-output-not-there/#findComment-13118177
