Hello,
I'm in the process of building a NAS, so far all I have is the computer case which is an In Win IW-MS04 Mini ITX Desktop Case.
Website: https://www.ipc.in-win.com/soho-smb-iw-ms04
Motherboards I'm intrested in ASRock Z390M-ITX/ac or Gigabyte X570 I AORUS PRO WIFI
No plans to Overclock.
Can anybody recommend a CPU and cooler?
Also if I go with the Gigabyte X570 I AORUS PRO WIFI, can you also recommend a (Low Profile GPU)?
Thanks,
https://linustechtips.com/topic/1133051-servernas-with-plexlaunch-box/
1 hour ago, GadgetMien said:
Hello,
Thanks,
Did launch box gain the ability to stream games? Last I checked it was just a nice way to interface to access them that also pulled some information from their databases. It allowed you to use a controller to browse the catalog and even support emulated games.
That all aside I don't think it streams them (unless that recently changed). I mean are you basically going for an HTPC then that also doubles as a plex server?
Now if just going more for a plex box I would do one of several things.
Grab a recent gen intel cpu for the improved quick sync capabilities.
Grab a 8-12 core amd for more software encoding power.
Go with a low end cpu and get a p2000, p2200 or from what I can see the new 1650s uses the new nvemc engine. The p2000 can handle around 20 streams, the 1650s would be limited to 2 unless you use the custom drivers then it could probably handle 4-8.
Lastly, you could just go cheap on hardware and make sure you convert the media to formats compatible with all your devices.
Thanks
